i googled that IC, but i still don't know how to implement it for switching the inductor in the SSHI...
From datasheet i can understand that you just set the resistors for a specific voltage parameter for which when it goes under that parameter the IC output goes high.
But with piezo the voltage input varies, it is not static...how can it monitor when the output is maximum, and what about when you are in the negative cycle?
