SSB Modulation
Discussion in 'Homework Help' started by omerysmi, Feb 14, 2015.
  1. omerysmi
    Oct 10, 2014
    44
    Does the contact between the amplitude of the message signal (Am) to the amplitude of the SSB signal (Vusb or Vlsb) is Am/2?
    In other words, if I will change the amplitude of the carrier signal (Ac) it will not effect the amplitude of the SSB signal?
    Thanks!
  2. Dodgydave
    Jun 22, 2012
    5,154
    772
    Yes it will effect the amplitude,the amplitude is the volume of the signal, SSB suppress the carrier,so it doesn't need a bigger bandwidth.
  3. omerysmi
    Oct 10, 2014
    44
    How can I calculate the amplitude of the SSB signal? doesn't it Am/2?
  4. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
  5. omerysmi
    Oct 10, 2014
    44
    I didn't find an answer for my question in this site.
    How can i calculate the voltage/amplitude of the usb or lsb signal?
  6. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
    Did you read this over there?
    Bertus
  7. omerysmi
    Oct 10, 2014
    44
    Yes but I didn't quite understand it . Why it is so difficult for your to give me the formula for calculating this?
  8. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
  9. Dodgydave
    Jun 22, 2012
    5,154
    772
    An AM transmitter of a 1000Watts would be the same as a SSB transmitter at 250Watts, with no loss of audio quality, ssb uses a quarter of the power needed of an AM set.
