I have problem with finding the RF AMP transistor --- SRF 2976. Can anyone help?
N Thread Starter Neil.S Joined Jul 4, 2010 3 Jul 4, 2010 #1 I have problem with finding the RF AMP transistor --- SRF 2976. Can anyone help?
beenthere Joined Apr 20, 2004 15,819 Jul 5, 2010 #2 That number does not seem to turn anything up. Got any other numbers? What are the operating parameters?
retched Joined Dec 5, 2009 5,207 Jul 5, 2010 #3 I have a problem finding 6.2 million dollars. Can anyone help? Just kidding. It appears to be an old motorola part. I would check with them regarding a replacement, or call these guys to see what they can do for you: http://www.rfparts.com/transistors_MRF-TP.html#SRF2072
N Thread Starter Neil.S Joined Jul 4, 2010 3 Jul 6, 2010 #4 I want to find some one to replace. But I even can't find the SRF2976 's datasheep. ------------------------------------------------ Thank you very much! I I have checked that part,but no one is proper. ------------------------------------------------ the transistor is used to the circuit that HF 30Mhz ,AM & SSB ,Last Stage AMP, 250mW(TIP) output Last edited: Jul 6, 2010
N Thread Starter Neil.S Joined Jul 4, 2010 3 Jul 6, 2010 #5 I had tried the MRF479. Maybe its' output capacitance is to big or other. when the Frequence reach 11Mhz,the output power reduce too much.
bertus Joined Apr 5, 2008 22,276 Jul 6, 2010 #6 Hello, Do you have the schematic where this transistor is used? This would give probably a better idea for a replacement. Bertus
