SRAM simulation in LT Spice
Discussion in 'Programmer's Corner' started by anju_john, Mar 17, 2016.
  1. anju_john
    Mar 17, 2016
    12
    Hi ,
    I am simulating the read and write operations of a 6T SRAM cell using LTSpice. But, i am not getting a proper output. The simulation results shows that the output (stored bits) changes with bitline even if the word line is low. Why it is so?
    The transistor (nmos ) output depends on the gate voltage right? Then why it changes with bitline?
    these are the results i got...
    Please help me.
    Thank you
  2. ronv
    Nov 12, 2008
    3,404
    1,492
    I think you need to use a "real" FET and not the generic one. You can do this by right clicking the FET and picking one from the standard library.
    If this doesn't work post your .esc files.
    anju_john likes this.
  3. anju_john
    Mar 17, 2016
    12
    Thank you for the reply. I tried with real FET. But still the same problem. i have attached the file
  4. Bordodynov
    May 20, 2015
    673
    194
    See
  5. anju_john
    Mar 17, 2016
    12
    Thank you so much....
    Could you please explain me the parameter .param Rleak = 1T
  6. kubeek
    Sep 20, 2005
    4,691
    806
    Apparently it overrides the default value of the parasitic resistance that is parallel to the capacitor, so that the capacitor has lower leakage than it would with default value.
  7. anju_john
    Mar 17, 2016
    12
    Thank you..
    Could you please tell me how to find the static noise margin of a sram cell in ltspice. i tried with the attached .sp file. but it is showing the errors BITCAP is not defined and U is not a source or temp. How can i resolve these errors.
  8. kubeek
    Sep 20, 2005
    4,691
    806
    Not sure about that, but you might try typing 0.000000000001 instead of 1e-12.
  9. anju_john
    Mar 17, 2016
    12
    Thank you
    I tried that... still not working.
  10. Bordodynov
    May 20, 2015
    673
    194
    Learn the syntax LTspice. Your file claims the Hspice syntax.
  11. anju_john
    Mar 17, 2016
    12
    Sure, i will try to learn it. Actually i tried to modify my schematic file for the snm analysis. Is it possible to do in this way, since i am not much familiar with the software. Also, how to give those equations to the sources in a schematic.
  12. Bordodynov
    May 20, 2015
    673
    194
    I fixed all your syntax errors. I do not understand your goals and what you do, and because nothing else did.
  13. anju_john
    Mar 17, 2016
    12
    Thank you so much. Actually my goal is to analyse the static noise margin of a 6T sram cell. For that i need to plot the butterfly curves and to measure the highest possible square inside the loops. When i referred some research papers, i saw that we need to mirror the inverted characteristics to get butterfly curves. i tried with dc sweep including two noise sources. but it was like nested sweep and i got some wrong results. so i modified the schematic based on some spice codes. here also i am getting only one proper curve. Since i am not much familiar and beginner in ltspice, i dont know the other possibilities. This is the actual problem. how can i mirror the inverter characteristics in order to measure snm.
    I need to get a graph as attached here
      File size:
      129.1 KB
      22
  14. kubeek
    Sep 20, 2005
    4,691
    806
    the two curves you showed don´t look like any kind of mirror image. Shoouldnt you just ramp the x axix back and forth and graph y axis?
  15. anju_john
    Mar 17, 2016
    12
    I was also a little confused with that. i have attached the reference. could you please check it ?
  16. kubeek
    Sep 20, 2005
    4,691
    806
    Now I see that you should mirror it along the x=y axis.
  17. anju_john
    Mar 17, 2016
    12
    How can we mirror x=y in LTspice
