So, for fun, I am planning on building a small SRAM module from transistors. I haven't decided on the exact size, but I'm thinking 4-bit word size and 4-bit address space (so, 16 words at 4 bits each. 64 bits total).
I've never designed SRAM before, except in simulations, and I'm not even 100% sure if the way I do it is practical in the real world or not. Usually, I have the data coming in going to every memory segment simultaneously, and I use a multiplexer to select which segment I want to take on the new value (to write to). Is this the correct way to do it? Is there a another/better way?
I then use a demultiplexer to select with address I want to read from, which also seems a bit impractical in the real world, because I'd have to have every single bit I have stored coming throw it to be routed back to my output.
My question has to do with the fact that multiplexers, as you increase their bit-width, actually increase in the number of transistors you need per address! To get only 16 addresses, I'm calculating that I'll need at least 100 transistors! And that's for a 1-bit word size! If I wanted to make a 4-wide by 16 SRAM module, I'd need more than 400 transistors in the multiplexer alone! I haven't even looked at the demultiplexer! Is it really this difficult to build SRAM? Is it really that impractical to build by hand?
Any other info would be greatly appreciated!
