SR Latch confirmation needed
Discussion in 'Homework Help' started by Kaiser, Dec 1, 2008.
  1. Kaiser
    Sep 18, 2007
    6
    in an SR latch, S=1, R=0 so Q=1 Q'=0, then S=0, R=0 and since that's the "latch" state, Q=1 and Q'=0 right? the S=0 and R=0 just means that Q and Q' stay unchanged or does it reset to it's initial state?
    I did indeed read http://www.allaboutcircuits.com/vol_4/chpt_10/2.html before I posted this, just wanting to make sure I understand it.
  2. mik3
    Feb 4, 2008
    4,846
    63
    If you are talking about a NOR gate RS latch, if R=0 and S=0 then Q and Q' stays unchanged (holds the previous value). For a NAND gate RS latch things work a bit different.
    Have a look here, it will help you:
    http://www.play-hookey.com/digital/rs_nor_latch.html
    You can click on the blue squares on the latch inputs and play with it.
  3. Kaiser
    Sep 18, 2007
    6
    Ah, thank you very much :D
