SR flip-flop
Discussion in 'General Electronics Chat' started by GTeclips, Mar 14, 2012.
  1. GTeclips
    Feb 18, 2012
    96
    Hey guys, sorry to bug you with yet another probably simple question.
    I have a little breadboard project I'm working on, and I need just one SR flip-flop. I searched Radio Shack, but all I found were Dual-D flip-flops and more complex IC's. Does anyone know of any good, reliable Single SR flip-flops dip IC's that would be relatively inexpensive and easy to obtain?
    Again, sorry to bother you guys with this simple question, Thanks for the view!
  2. MrChips
    Oct 2, 2009
    12,623
    3,451
    For a simple S-R flip-flop you can use two NAND gates or two NOR gates, and you will have two spare gates.
  3. GTeclips
    Feb 18, 2012
    96
    I suppose that would work. If this was to be the case, I would need to know of a dual nand dip IC (I already know of quad nand dip IC, but my circuits is low on space and I need as many open grooves as possible). Thank you for the idea!
  4. ErnieM
    Apr 24, 2011
    7,434
    1,625
    They don't come in duals AFAIK. Typically quads, and now a days singles in microscopically small SMD packages.
    RS may well have them.
  5. GTeclips
    Feb 18, 2012
    96
    So, the only way to make a single SR would be to use a quad nand? They don't have prepackaged SR's?
  6. MrChips
    Oct 2, 2009
    12,623
    3,451
    Are you looking for TTL or CMOS? TTL 74LS74 is pretty much standard.
  7. GTeclips
    Feb 18, 2012
    96
    Okay, thank you. I personally prefer TTL over CMOS. Another question I was wondering, (sorry if you already answered this) instead of using 2 nand gates to make an SR, could you just use 2 not gates?
    EDIT: And could you also use 3 not gates to make a pulse generator?
  8. MrChips
    Oct 2, 2009
    12,623
    3,451
    1) It is possible to use two NOT gates to make an S-R flip-flop, depending on what you are using to generate the S and R. You will have to show your circuit.
    2) You can use three NOT gates to make an oscillator. You can also do it with a single Schmitt trigger NOT gate. You can substitute a 74LS14 hex Schmitt trigger inverters for regular 74LS04 inverters.
  9. Ron H
    Apr 14, 2005
    7,050
    657
    74LS279 is a quad SR latch, with negative true inputs. 74HC279 is also available.
  10. GTeclips
    Feb 18, 2012
    96
    Thanks for the chip number Ron!
    MrChip, I'm trying to upload my diagram, but I'm having trouble uploading it my usual way (photo bucket). Are there any other ways?
  11. GTeclips
    Feb 18, 2012
    96
    Sorry that this isn't a real diagramming software, its a logic simulator, but its the best I have.
    TOP: SR flip-flop
    BOTTOM: Oscillator
  12. MrChips
    Oct 2, 2009
    12,623
    3,451
    If you just wish to demonstrate an S-R flip-flop using NOT gates, here is a simple circuit:
  13. MrChips
    Oct 2, 2009
    12,623
    3,451
    Here is a simple oscillator using a single 74LS14 Schmitt trigger inverter.
    I will provide component values later after I get a chance to test it on a breadboard.
  14. GTeclips
    Feb 18, 2012
    96
    Thank you MrChips, I'm trying to make an SR flip-flop using a NTE 74C04 TTL 14 dip hex inverter IC, but I believe I am wiring it incorrectly because it will not function properly.
  15. MrChips
    Oct 2, 2009
    12,623
    3,451
    Try 74LS04 instead.
  16. MrChips
    Oct 2, 2009
    12,623
    3,451
    Here is a working circuit for an oscillator from a single 74LS14 inverter.
    The second inverter is there only to drive the LED.
    The RC values will give a frequency that is visible on the LED. You may change R and C to suit. Typical range for R is 100 to 4700 ohms.
  17. GTeclips
    Feb 18, 2012
    96
    I see how that works, but I'm a little frustrated that it won't work with the 74C04, what is the major diffrence bettween the 74C04 and the 74LS04, because I already have a 74C04, and I only want to get additional chips if necessary? (BTW I'm talking about the SR flip-flop.)
  18. MrChips
    Oct 2, 2009
    12,623
    3,451
    When one push button is pressed and held pressed, does the corresponding LED come on?
    What happens when you release the push button?
  19. GTeclips
    Feb 18, 2012
    96
    Wait, do you mean a button conected to the IC, the connected to a led, or just a button conected to a led?
  20. MrChips
    Oct 2, 2009
    12,623
    3,451
    Now I have no idea what you are talking about.
    Maybe you should post a photograph of your setup.
