Squeaking fridge
Discussion in 'Off-Topic' started by cmartinez, Dec 20, 2015.
  1. cmartinez
    Thread Starter AAC Fanatic!
    Jan 17, 2007
    3,698
    2,779
    So I've got this 7-year-old, two vertical doors LG refrigerator that has begun to squeak loudly... what does it mean? That it's just about to die on me, or will it still last a few more years before it makes its final ice cube? Is it the compressor, or just the fan?
    Or.... maybe I have to call a qualified technician to know what's going on.
    Paging @#12
  2. MaxHeadRoom
    Jul 18, 2013
    10,838
    2,512
    Did you try pulling it out and pinning it down to a particular area, have you checked the freezer fan?
    Max.
  3. djsfantasi
    Apr 11, 2010
    2,902
    878
    Any belts on the compressor?
  4. #12
    Nov 30, 2010
    16,673
    7,320
    No.
    Keep talking Martinez. It squeaks whenever the freezer fan is blowing? It squeaks when you open the right door but not the left door? Give me some clues.
    Sinus23 and cmartinez like this.
  5. cmartinez
    Jan 17, 2007
    3,698
    2,779
    It's squeaking right now... and I'm under the impression that it's the fan. Because I can hear (more like feel) the compressor humming along just fine.
  6. MaxHeadRoom
    Jul 18, 2013
    10,838
    2,512
    Normally you can see the freezer fan when you open the door, should be possible to detect if this is location of the squeak.?
    The compressor is a little remote from it.
    Max.
    cmartinez likes this.
  7. #12
    Nov 30, 2010
    16,673
    7,320
    The fan underneath?
    Both doors open...Take off the front kick panel with a frontward jerk near the left and right ends. It's probably a snap-on. Look underneath for dust bunnies in the compressor fan. Come equipped with a wet&dry vac that can blow and a small, weak, hairbrush taped to a meter stick. 1/4 inch hex screws remove the thick paper back off the compressor and fan section.
    Squeaking in the cold places? That's a different fan.
  8. cmartinez
    Jan 17, 2007
    3,698
    2,779
    Also, a few year ago hurricane Alex hit us real hard, we were left with no clean water for a few days. The water was flowing full of dirt out of the faucet. That's when the icemaker and the water dispenser stopped working. Even though the thing has a filter, I'm sure some dirt reached the solenoid valves and stuck them for good.
  9. cmartinez
    Jan 17, 2007
    3,698
    2,779
    Thanks, Max and #12. I'll do that tonight... thought I'm pretty sure it's the fan outside of the fridge. Gotta go for now.
  10. #12
    Nov 30, 2010
    16,673
    7,320
    @cmartinez
    Don't forget to clean the pee pan while you're under there.
    It seems obvious to check the intake filters on the water dispenser solenoids. If they stick open, you have water all over the place, so they must seems stuck closed.
  11. tracecom
    Apr 16, 2010
    3,878
    1,396
    Look for mice.
    #12 likes this.
  12. spinnaker
    Oct 29, 2009
    5,069
    1,176
    They can be pesky
    #12 likes this.
  13. tracecom
    Apr 16, 2010
    3,878
    1,396
    Not that gringo mouse!
    This mouse:
    #12, JoeJester and cmartinez like this.
