Squaring microamps
ElectricMagician
Joined Jul 26, 2012
57
To calculate power due to a current in the uA range (say 25 uA) and a known resistance (say 50 Ohms), which is correct?
P = (25 * 10^-6) ^2 * 50 Watts
P = 25^2 * 10^-6 * 50 Watts
This has confused me because I know that a square with sides of 1cm has an area of 1 cm2, not 1*10^-4 m2, but to do it this way does not seem mathematically accurate
Robartes
Joined Oct 1, 2014
57
The first.
Sure it is. 1 cm * 1cm = 10^-2 m * 10^-2 m = 10 ^-4 m^2. 1 cm * 1cm is also 1 cm2.
Edit: keyboard ate my ^2 after 10^-4 m. Added it again.
WBahn
Joined Mar 31, 2012
30,062
Only if you believe that
\(a \cdot b\)^2 \; = \; a^2 \cdot b
If all else fails, walk it through in full detail and TRACK YOUR UNITS!
\text{
P \; = \; I^2R
P \; = \; \(25\mu A\)^2 50\Omega
P \; = \; \(25 \strike{\mu A}\ \cdot \frac{1A}{10^{6} \strike{\mu A}}\)^2 50\Omega
P \; = \; \(25 \times 10^{-6} A\)^2 50\Omega
P \; = \; 625 \times 10^{-12} A\)^2 50\Omega
P \; = \; 31250 \times 10^{-12} A^2 \Omega
P \; = \; 31.25 \times 10^{-9} \strike{A^2 \Omega} \cdot \frac{1W}{1 \strike{A^2\Omega}}
P \; = \; 31.25 \times 10^{-9} W
P \; = \; 31.25 \times 10^{-9} \strike{W} \cdot \frac{10^{9}nW}{\strike{W}}
P \; = \; 31.3 nW
