I'm not sure why you mentioned this, but absolute pressure is zero-referenced against a perfect vacuum. Negative pressure can only exist in gauge pressure measurement, which is referenced against ambient air pressure.The absolute pressure of an explosion is positive.
Since Earth has some air pressure then a vacuum is negative absolute pressure.
I'm not intending to argue here - just to add something to the discussion.Hey Russ, If a church organist was playing the church organ yesterday and the Leslie speakers stopped at 60 degrees rotated (measuring clockwise from the top) from facing forward, then he went home and came back today with you, then started playing the church organ, what phase shift could you name from hearing the speakers that stopped yesterday?
Anwer: none. "Human hearing is generally considered to be insensitive to phase".
The sound is certainly phase shifted from what it would be if the speakers were facing forward. We know that because we can hear the phase shifting that happens when the speakers are spinning. (Otherwise, the Leslie Speaker Corporation would never have existed.) So, we humans can hear changes in phase, that is, relative to the sound just previous, but we can't get any phase information from a phase shifter that is not moving. Using the idea of relative phase, I came up with "absolute phase". If that is a worthless phrase, what do you call the thing that we can not perceive because the phase is not changing?
"Humans can not perceive_______________."
Are you talking about phase changes of the harmonics of a complex sound, relative to the fundamental, or phase changes in a single tone, or both? Or something else?Ron, I would tend to buy into the idea that humans are hearing the cancellations and vibrato of a Leslie speaker system, and mistaking them for phase shift, except for studies on how human throats create the vowel sounds. The results of those experiments were described as phase changes. This information also led me to the idea that humans can judge relative phase changes (relative to the sound just previous).
If he's referring to a single tone, he'd be correct. If he means to phase-shift the entire composite waveform without independently shifting each frequency, then he'd also be correct. HOWEVER, if he means that each separate frequency that makes up a waveform, when phase shifted, still isn't detectible, then he'd be incorrect.Are you talking about phase changes of the harmonics of a complex sound, relative to the fundamental, or phase changes in a single tone, or both? Or something else?
Phase shifting of what, relative to what?The vowel sounds are produced by phase shifting
The Doppler effect on frequency and phase is different.Changes in phase of a single tone result in changes in frequency of that tone (f=dΦ/dt). Does the ear detect changes in phase, or in frequency, or both? Perhaps it doesn't matter what the mechanism is.
If you could make an instantaneous phase change in the second of two cycles,( not making any more phase changes from then on),comparing the period of the first cycle to that of the second,the second cycle would appear to be one cycle of a different frequency,as its period would be different to the previous one.The Doppler effect on frequency and phase is different.
When the airplane is coming towards me its engine pitch is increasing, When it goes past me its pitch is decreasing. The frequency changes but I don't know and I don't hear what the phase does.
Changing the phase of a tone does not change its frequency!
by Jake Hertz
by Jake Hertz
