Square wave oscillator using LM393 comparator
Discussion in 'General Electronics Chat' started by hrs, Mar 12, 2016.
  1. hrs
    Jun 13, 2014
    86
    7
    After breadboarding a square wave oscillator according to the attached circuit diagram, I measured it at slightly over 11 kHz at 2.5 V peak to peak. If I do the frequency calculation with R3 = 1k and C1 = 35nF(measured) 11 kHz is about right.
    I don't understand the operation of the circuit. Suppose that at some point in time C1 is discharged and the output just went high, C1 will now charge through R3 until the voltage at B is higher than the voltage at A (4.5 V). Now the output goes low and starts to drain C1. Pretty much immediately the voltage at B will be lower than the voltage at A and the output will go high again, oscillation occurring at infinite Hz. But it doesn't. Why not?
    Looking at the functional block diagram on page 9, I think for logical low output pin 1 sinks current to the potential on pin 4. For logical high the output transistor is cut off and a pull-up resistor pulls the output up, to 9 V in my case. So where does the current come from that charges C1? It can't be through the pull-up resistor because it would change the frequency by a lot.
    Why am I only seeing 2.5 V peak to peak and not 9 V? I'm not sure if my scope is 1M or 2M ohm input impedance, but with my 10M ohm multimeter I see the same voltage. I'm not seeing the attenuator if there is one.
  2. mcasale
    Member
    Jul 18, 2011
    210
    12
    The LM393 has an open-collector output. So when the output is HIGH (ie open circuit) the capacitor charges through R3+R4. The voltage at C is almost the same as B.
    When the capacitor voltage (B) hits 4.5 volts the comparator output sinks current and discharges the capacitor through R3 only.
    So, the charge and discharge time-constants are different. That means the resulting output signal will have a DC offset.
    If you want the output to go from ground to 9V (almost), you need to set the time-constants long enough to allow full charge and discharge times. Try swapping R3 and R4 and it will be more symmetrical.
  3. hrs
    Jun 13, 2014
    86
    7
    Thanks mcasale, I'll try some different values for R3 and R4. So the charging does occur through R4. Then I need to reconsider how the frequency is calculated. Also it just occurred to me that I need to look at B vs GND on my scope to see what it looks like, tomorrow.
    Still I don't understand how C1 gets time to discharge. Suppose A is fixed at 4.5. B rises to 4.50000000000001. Output goes low. In no time B falls to 4.499999999999999999999. Output goes high. Etc. But this is not what happens. Maybe if I scope B to GND I'll get some clues.
  4. mcasale
    Member
    Jul 18, 2011
    210
    12
    Yes, you are correct, I think. Now that I look more carefully, pin 2 should oscillate around 4.5 volts, and its amplitude is determined by the offset voltage between pins 2 and 3. The capacitor will not totally discharge (or charge), but will operate almost linearly at a fraction of the time constant. In order to get a full 9V output, try switching to a non-open-collector comparator. Then the output will switch between 0 and 9 volts.
    Still, the charge and discharge time constants are different, so it will not be symmetrical.
    What are you trying to do with this circuit?
  5. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,696
    1,297
    This is not the standard opamp squarewave oscillator. It is missing a hysteresis resistor from the output to the + input. If you install a 1 M as a starting value, that will be 5% hysteresis, probably enough to get things to behave. The output now will swing the down to GND. It still won't go all the way up to Vcc, but it will be closer. Also, the frequency probably will decrease. As you decrease the hysteresis resistor the frequency will continue to lower.
    Having an asymmetrical output impedance makes calculating the theoretical output freq more difficult, and as mentioned the output will not be symmetrical.
    ak
  6. Jony130
    Feb 17, 2009
    3,991
    1,116
    It's really hard to believe that this circuit indeed is oscillating. As point out by AnalogKid this circuit is not a standard opamp squarewave oscillator.
    Because the "standard circuit" use a hysteresis to generate a square wave. But in your circuit we do not have any hysteresis resistor (RH resistor in the diagram below).
    And this means that if your circuit really osculating this oscillation are caused by a phase shift in the negative feedback loop. And your circuit on the breadboard fulfils the condition needed to start oscillations. So you are very lucky man.
    http://www.allaboutcircuits.com/tec...ve-feedback-part-4-introduction-to-stability/
    Also as a side note, your LM393 has an open-collector output so it is always good to choose R4 (pull-up resistor) much smaller in value than the rest of the resistors connected to the output. So, R4 should have the smallest value in the circuit R4 << R3 and RH
  7. dannyf
    Sep 13, 2015
    2,196
    417
    Because the 'opamp' here has an open collector output so the charging up is done via a current source formed by vcc and r4.
    To put it the other way, had you used a real opamp with a pp output stage, the oscillation would be happening at much higher frequencies for exactly the reason you mentioned.
    This oscillator is equivalent to is rc oscillators built with CMOS input stage. The suggested changes would make it similar to rc oscillators built from a st input stage.
  8. hrs
    Jun 13, 2014
    86
    7
    Doh! I see now that I forgot a resistor between the non-inverting input and the output in the diagram ... On my breadboard there is a 47 kOhm resistor between pin 1 and 3, I was looking at an incorrect diagram. So the non-inverting input does not simply sit at 4.5 V, it will shift with the output through the hysteresis resistor.
    Thanks everyone for your replies.
    DickCappels likes this.
  9. hrs
    Jun 13, 2014
    86
    7
    After some corrective circuitry I tried to re-analyse the oscillator and I was hoping that someone might look at it to see if the if it's any good. I tried to look at the general operation and what influences the output signal voltages. When I have more time I'll try to figure out why it's not oscillating for various values.
    When V_input < V_inverting_input, the comparator output is shorted to ground:
    R_parallel = R2*R3/(R2+R3)
    V_A = V_bat * R_parallel / (R1 + R_parallel) = 0.1V
    V_C = 0V
    The voltage at B will drop to V_A. At this point the comparator output transistor goes open circuit.
    Remove R3 and find Thevenin's equivalent resistance, the current through R3:
    V_A = V_bat * R2 / (R1 + R2)
    V_B = V_bat * R5 / (R4 + R5)
    dV_Thev = V_B - V_A
    R_Thev = 1/(1/R1 + 1/R2) + 1/(1/R4 + 1/R5)
    I3 = dV_Thev / (R_Thev + R3)
    V_AB = dV_Thev * R3 / (R_Thev + R3)
    The current through R2 = I1 + I3:
    V_bat - I3*R2 = I1*R1 + I1*R2
    I1 = (V_bat - I3*R2) / (R1 + R2)
    V_A = (I1 + I3)*R2
    V_C = V_A + V_AB = 7.0V
    In conclusion the above suggests a peak to peak voltage at C of 7V. On a scope I see about 3V. If you have any ideas on this I'd love to hear it.
  10. RichardO
    May 4, 2013
    1,341
    429
    Some quick comments:
    The peak to peak voltage is not the important value. The positive feedback sets thresholds that the capacitor charges and discharges between. What is important is whether the capacitor can truly get to both of these voltages.
    Your equivalent circuits are not quite. They only apply during startup and/or if the circuit does not oscillate. When the circuit is oscillating, the peak voltages on the capacitor are set by the positive feedback. The capacitor-end of R5 never goes to +9 volts or ground. This means that the current through the R5 is less than you estimated.
    My mental calculations say that the circuit is marginal. It may or may not oscillate with real world tolerances of components. As mentioned earlier, the major cause of this is the too-high value of the pullup resistor, R4.
    One goal of engineering is to keep things simple. By simply keeping the pullup resistor small relative to the loads it has to drive most of your analysis is unneeded. Also, by keeping the thresholds small relative to the supply voltage, the loading on the pullup resistor becomes less critical.
    There are limits to how large and small R4 can be. The LM393 can only sink a limited amount of current and your battery will last longer with larger resistor values. Conversely, if R4 is too large, then the feedback resistors can be too large relative to the input resistance/bias currents of the LM393 and the leakage current of the timing capacitor.
    hrs likes this.
  11. Jony130
    Feb 17, 2009
    3,991
    1,116
    Va at time when comparator output transistor goes open circuit is equal to
    Va = Vcc * R2/(R1|| (R3+R4) + R2) = 9V * 100kΩ/ (100kΩ||57kΩ + 100kΩ) = 9V* 100kΩ/ (36.3kΩ+ 100kΩ) ≈ 6.6V
    In real life this voltage will be smaller due to loading effect by R5. (try lower R4).
    Va at time when comparator output is shorted to ground
    Va ≈ Vcc* (R2||R3)/( (R2||R3) + R1) = 9V*32kΩ/(132kΩ) ≈ 2.1V (I ignore LM393 saturation voltage)
    This sill give us the output frequency equal to Tlow+Thigh:
    Tlow ≈ 47kΩ*35nF * ln(6.6/2.1) = 1.88ms . The capacitor is discharging from 6.6V to 2.1V via R5 resistor.
    Thigh ≈ (47kΩ+10kΩ)*35nF *ln [ (9 - 2.1) / (9 - 6.6) ] = 2.1ms I ignore R5 resistor influence.
    And this time the cap is charging from 2.1V to 6.6V via R4+R5
    Fout = 1/(Tlow + Thigh) = 251Hz
    And tomorrow I will try to build this circuit I see if theory agrees with practice.
    hrs likes this.
  12. Jony130
    Feb 17, 2009
    3,991
    1,116
    Today I build this circuit on the breadboard.
    I use the same component value as shown on the diagram. And my Rigol show this result
    Red trace is a Vc voltage (output)
    Blue trace is a Va voltage (non inverting input)
    Purple or violet Vb trace is a voltage across the capacitor ( inverting input)
    As you can see the output frequency is 257Hz and output voltage swings between 0V and up to 8.4V or so.
    As you can see real world result confirms the theory.
    The LTspice shows this
    And If I change pull-up (R4) resistor from 10k into 1k I receive this beautiful square wave at the output
    RichardO, hrs and anhnha like this.
  13. hrs
    Jun 13, 2014
    86
    7
    In this configuration I can remove R4 and it will continue oscillating. If I put in 1k for R4 I get an uneven duty cycle, about 1:2. So I guess there's some stupid mistake in my breadboard circuit ... I'll redo it from scratch.
    But it's ok for the Thevenin thingy isn't it? Short the capacitors and voltage sources in order to find the voltage at A the moment the comparator output goes high.
    Thanks for showing the calculation, it's really helpful. Is my approach for when the output transistor goes open circuit incorrect or simply more complicated than needed?
    Edit: Oh, and what type of LTSpice analysis do you use for a circuit like this? Is it a transient analysis? I couldn't get it to work but then I don't know what LT comparator to pick ...
  14. Jony130
    Feb 17, 2009
    3,991
    1,116
    Because now R1 and R3 acts as "very poor" pull-up resistor and if you got lucky the circuit will oscillated
    In this case your approach is wrong and too complicated at the same time why? Because the voltage at the capacitor is not equal to 0 volts, so you cannot short the cap.
    Yes I used transient analysis and LM393 from library.
    hrs and RichardO like this.
  15. hrs
    Jun 13, 2014
    86
    7
    Understood.
    After rebuilding I get the same results as you showed on your Rigol. With a 10k pull-up I also see the drooping leading edge and with 1k it's a nice looking square wave. Thanks again!
