Do you ask this because stability can be changed by modifying the attached components?You left out a lot of information, such as:
Frequency range
Frequency stability requirement
Power supply voltage
Output voltage and current capability
Minimum and maximum duty cycle
My mind did not automatically gravitate to the 555. The question of stability is always relevant when an oscillator is called for.Do you ask this because stability can be changed by modifying the attached components?
Or do you ask to determine if the 555 is able to have a stability of "X" and if not, you need to use a different strategy/chip?
Ok, there's the answer!My mind did not automatically gravitate to the 555. The question of stability is always relevant when an oscillator is called for.
I'm waiting for an answer from the OP. He probably can't give us a quantitative answer, but he can tell us his application, and we can go from there.Ok, there's the answer!
What would you gravitate to?
by Jake Hertz
by Duane Benson
by Jeff Child
by Aaron Carman
