Square Wave Generator Construction
Discussion in 'The Projects Forum' started by ifiaxxy, Jul 21, 2014.
  1. ifiaxxy
    Jun 5, 2014
    10
    hi, I am building a circuit with op-amp to generate a square wave. The circuit diagram is shown here: http://hyperphysics.phy-astr.gsu.edu/hbase/electronic/square.html#c4
    The op-amp I use is TL074 and when I run it, there is a problem: I get the square wave in the first few minutes (like 20min or so) and then the output becomes a constant voltage. All my resistors are 10k and my capacitor is 4.7uF.
    Can anyone help me fix this problem? I want the circuit to generate the square wave constantly for up to 12hr.
    Thank you!
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    What are the supply voltage(s)?
  3. to3metalcan
    Member
    Jul 20, 2014
    228
    23
    If you restart it, does it start running again?
  4. Bernard
    Aug 7, 2008
    4,242
    417
    Seems like there should be a R3 from + supply to + input. Difficult to discharge C to below ground when discharge path is ground or near ground.
  5. ifiaxxy
    Jun 5, 2014
    10
    the supply voltage is 12V
  6. ifiaxxy
    Jun 5, 2014
    10
    Yes, it runs again, but the same thing happens
  7. djsfantasi
    Apr 11, 2010
    2,911
    881
    +/- 12VDC? Or just 12VDC? Note that the circuit you linked to requires a +/- power supply.
  8. Veracohr
    Jan 3, 2011
    559
    77
    The oscillation runs fine for about 20 minutes, then stops? Maybe it's the JFET-input opamp latching up. Do you have a different opamp model you can try?
  9. ifiaxxy
    Jun 5, 2014
    10
    It's + and - 12V DC
  10. ifiaxxy
    Jun 5, 2014
    10
    This is the only op-amp I've got... I think the op-amp is still working though, because when I unplug the power supply and put it back on, it works again
  11. wayneh
    Sep 9, 2010
    12,396
    3,246
    And "ground" is at 0V, right? In other words, you haven't confused V- and ground?
    Is there a load on Vout that might be causing the op-amp to overheat and shut down?
  12. ifiaxxy
    Jun 5, 2014
    10
    GND is 0V and when I run the circuit, the op-amp doesn't get hot, so I guess there's no overload
  13. wayneh
    Sep 9, 2010
    12,396
    3,246
    OK, just wanted to check the "obvious" stuff.
    How about putting a 0.1µF decoupling cap on the op-amp's power pins? Maybe it's falling into an oscillation of some kind.
  14. ifiaxxy
    Jun 5, 2014
    10
    for a decoupling capacitor, do you mean that I can simply connect Vcc+ and Vcc- with a capacitor?
  15. to3metalcan
    Member
    Jul 20, 2014
    228
    23
    Run a cap from each power pin to ground...reduces the chances of hf oscillation swamping out your square wave. Also, tell us about your main timing cap. What value? What type? Have you tried swapping it for another?
  16. djsfantasi
    Apr 11, 2010
    2,911
    881
    No. Use two caps. One from Vcc+ to ground and the second from Vcc- to ground.
  17. to3metalcan
    Member
    Jul 20, 2014
    228
    23
    I'm guessing your 4.7uF is electrolytic...they're not always great for oscillators. If bypassing doesn't help, try increasing the value of R and using a smaller C...a value you can get as a film or ceramic.
    ifiaxxy likes this.
  18. to3metalcan
    Member
    Jul 20, 2014
    228
    23
    Or just try a different cap! See if you can get oscillation at any frequency.
  19. Brownout
    Jan 10, 2012
    2,375
    998
    What voltage? Also, where are you connecting the ground?
