Square wave frequency to binary conversion question.
Discussion in 'The Projects Forum' started by bushrat, May 30, 2016.
  1. bushrat
    Nov 29, 2014
    97
    23
    Hello everyone..
    Is there any IC known out there or a circuit that would convert square wave signal to binary?
    Range would be from 100 Hz to 1 kHz (possibly up to 10 kHz).
    Looking for circuit without microcontroller involved.
    Thanks in advance,
    BushRat.
  2. AlbertHall
    Jun 4, 2014
    2,250
    445
    A binary counter enabled for one second would do it.
    It'd be a lot easier with a PIC though.
  3. shteii01
    Feb 19, 2010
    3,497
    511
    By square wave, do you mean series of square pulses?
    Meaning that you are not actually sending square wave, because square wave has half of wave period low and half of wave period high. If you send two square pulses in a row that are high, then half the period is high and other half the period is also high.
  4. bushrat
    Nov 29, 2014
    97
    23
    0-5 V pulses.
    0 V would be low, and 5 V would be high.
