square triangle wave generator -[NOob]
Discussion in 'Homework Help' started by Santa klaus, Nov 16, 2014.
  1. Santa klaus
    Nov 16, 2014
    28
    I did the simulation for square triangle wave opamp on ltspice. but i don't know where to put the input signal. i get zero signals everywhere help
  2. RichardO
    May 4, 2013
    1,350
    432
    You have told LTspice to stop simulating at 2 seconds. What frequency do you expect to see?
    Also, it is often a problem using an op-amp without selecting a specific part. LTspice defaults to a model that does not always do what you would expect.
  3. Santa klaus
    Nov 16, 2014
    28
    i tried increasing simulation time but i don't get the square and triangle signals. there is no signal at all
  4. Jony130
    Feb 17, 2009
    3,995
    1,117
    Upload your asc file
  5. RichardO
    May 4, 2013
    1,350
    432
    Did you select specific models for the op-amps?
    You need to answer the question... What frequencies do you expect to see?
  6. Santa klaus
    Nov 16, 2014
    28
    i used a universal opamp. I would like to have an input signal of amplitude 5 at 5Hz and an output at 5Hz.
  7. shteii01
    Feb 19, 2010
    3,519
    515
    Does not compute for me.
  8. Santa klaus
    Nov 16, 2014
    28
    maybe my question wasn't clear. what i meant was, do i need to apply an input voltage at the first stage, or is the circuit supposed to work like this. I am confused because there needs to be an input voltage/current for an opamp circuit, right?
  9. shteii01
    Feb 19, 2010
    3,519
    515
    Astable multivibrator does not need external input to start it.
  10. MikeML
    Oct 2, 2009
    5,451
    1,066
    Load this and run it. I want you to tell me why it works now...
  11. Santa klaus
    Nov 16, 2014
    28
    great it works. i don't know why though. could you explain the .ic V(Y) = 1u?
  12. crutschow
    Mar 14, 2008
    13,529
    3,393
    An alternate way to get it to oscillate is to check the "Skip Initial operating point solution" (uic) in the "Edit Simulation Command" box.
    Hint: The no-oscillation problem is related to the calculated circuit DC initial operating point that Spice performs at the start of the simulation by default.
    As another interesting experiment with this problem, try injecting a small single short current pulse (say 1us, 1ua) into the input of one of the op amp inputs delayed by 1ms (without the .ic or uic commands).
  13. MikeML
    Oct 2, 2009
    5,451
    1,066
    That is the key to making it oscillate. Prior to a TRANSIENT (time domain) simulation, all Spice-derived simulators try to place all of the nodes in the circuit to a voltage derived from the way the circuit is biased. That puts the nodes where the circuit is ready to do what it is going to do later, but because, unlike in the real world, the simulation is noiseless, there is no perturbation to get amplified so that oscillation starts.
    Try Goggling "metastability".
    The .ic directive tells LTSpice that you want to override the zero V that would have come from the bias solution at node Y with 1uV instead. When the time domain solution begins, the feedback loop is now unbalanced (by a tiny 1uV), but that is amplified and the feedback causes the oscillation to begin (immediately). There are an infinite number of ways to create this initial perturbation that it takes to get the circuit going...
    This is a common problem when simulating oscillators. You have to account for the normal thermal noise that is naturally occurring in any circuit when dealing with oscillators...
    absf likes this.
  14. JoeJester
    Apr 26, 2005
    3,403
    1,230
    You don't need initial conditions IF you can start the transient analysis at zero and not compute the operating conditions prior to the start of the analysis.
    Here are my options for doing a transient analysis. I typically start with zero and do not need to apply initial conditions .... even when using the ideal op amps.
  15. MikeML
    Oct 2, 2009
    5,451
    1,066
    I quote myself:
    The metastability problem comes up only in simulating oscillators or flip-flops; not with amplifiers. Skipping the initial DC bias solution is not appropriate for most of the circuits you will simulate.
