Square root of complex
Discussion in 'Math' started by TheSpArK505, Dec 30, 2014.
  1. TheSpArK505
    Sep 25, 2013
    92
    Hello guys,
    I wnat to take the square root of a complex over complex, i have set my calculator(casio fx-991ES plus)
    to complex but when i try to calculate it gives me math error!!!! is there any set ups or its impossible to take square root of complex
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Don't know about your particular calculator capabilities.
    It's not that difficult a computation - if that's your main concern.
    Starting with the original complex ratio value as a single value polar form, the square root is readily determined - as you presumably know. If your calculator can do the complex division and display the result in polar form the last step is relatively easy.
    The polar form of the square root
    \sqrt {A \angle {\pm \theta}} =\sqrt {A} \angle\pm \frac{\theta}{2}
  3. TheSpArK505
    Sep 25, 2013
    92
    Thanks it's easier now;)
  4. MrAl
    Distinguished Member
    Jun 17, 2014
    2,561
    517
    It might also help sometimes to remember:
    sqrt(A/B)=sqrt(A)/sqrt(B)
  5. russ_hensel
    Jan 11, 2009
    820
    47
    In the square root you can add 2pi to theta ( one or more times ) before dividing the angle to get other square roots ( here just 2 in total)> More for cube roots, 4thf roots, etc.
  6. amilton542
    Nov 13, 2010
    494
    64
    Yeah it's called De Moivre's theorem.
  7. Motanache
    Member
    Mar 2, 2015
    109
    5
  8. WBahn
    Mar 31, 2012
    18,087
    4,917
    Because some people want to actually learn the concepts behind the math instead of just letting a tool written by someone else do their thinking for them.
