Square Root Implementation Help
Discussion in 'The Projects Forum' started by zubizaretta, May 13, 2013.
  1. zubizaretta
    May 13, 2013
    Hi , I have designed a Non-Restoring Square Root circuit which roots 4 bit numbers. It works perfectly on Multisim. Transfered it to Ultiboard. Have no DRC errors. Ready to be a PCB but I am still stressed that , could Ultiboard made a mistake while autorouting or can It be able to work in real life? Sınce this is my homework I am stressed.
    I am attaching the Multisim file and Ultiboard file. I would love to have some advice.
  2. wayneh
    Sep 9, 2010
    12,405
    3,256
    You should post pictures to get a better response. Many here that might help simply won't, if they can't easily take a look.
    zubizaretta likes this.
  3. zubizaretta
    May 13, 2013
  4. wayneh
    Sep 9, 2010
    12,405
    3,256
    Here they are
  5. zubizaretta
    May 13, 2013
    thx :) so this works perfectly fine on Multisim. would it also work in reality :)
  6. ErnieM
    Apr 24, 2011
    7,445
    1,628
    Typically the connectivity is good as you can check that with the design rule checker. Same for spacing as long but only as your rule set is simple.
    I've found in professional settings a PCB needs somewhere between 2 and 3 spins to come out as something acceptable, and perfection is not possible. This number doesn't seem to correlate to how many people give the design a look.
    The Thing that helps the most is printing out the layers and seeing if the physical parts fit on the footprints.
    If it doesn't work in Multisim it probably doesn't work in reality.
    If it does work in Multisim it probably will work in reality.
    That's why some people still simulate using the SOLDER program.
    However... if you miss it your prof will probably also miss it in a homework assignment.
