square oscillator
Discussion in 'General Electronics Chat' started by fourty, Feb 2, 2014.
  1. fourty
    Oct 13, 2013
    13
    the circuit didn't work in multisim plz someone can help me? i can't found the problem
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    The signal can not go below ground.
    If you would feed the LM741 with + and - 6 Volts, the circuit would work.
    Bertus
  3. LvW
    Jun 13, 2013
    674
    100
    Normally, opamps are used with double supply because they are designed for such applications. However, they can be used, of course, with one single supply voltage only - however, in this case, some special provisions/circuitry is necessary for proper biasing.
    Fourty, my recommendation is that you become familiar with both supply alternatives.
  4. Alec_t
    Sep 17, 2013
    5,979
    1,138
    Here's how you could configure the circuit.
    N.b. you won't get a good square wave using a 741; it's bandwidth is too limited (as evidenced by the sloping flanks of the waveform shown).
  5. LvW
    Jun 13, 2013
    674
    100
    To me more specific: It is the bad 741 slew rate (0.5V/µs) which causes the sloping flanks.
  6. MikeML
    Oct 2, 2009
    5,451
    1,066
    Also, the 741 is not rail-to-rail on the output pin, so the output stops short of going to 12V and 0V. The reduced amplitude output also effects the trip points at the inverting input, so indirectly effects the frequency as well. All-in-all, the 741 is about the worst opamp you can use for a circuit like this.
