Spruce Goose with muscle
Discussion in 'Off-Topic' started by jpanhalt, Aug 31, 2009.
  1. jpanhalt
    Thread Starter AAC Fanatic!
    Jan 18, 2008
    5,699
    909
    Known as the Russian K7, it is reported to have flown 11 times before crashing. At least that is the story I saw. I don't think the could fire the canons simultaneously in a broadside.
    What a great project for Bernard.
    John
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. jpanhalt
    Jan 18, 2008
    5,699
    909
    I guess it is just a mock up of some design that really never flew. The actual K7, which was un-armed and smaller, did fly. I'll have to talk to my usually reliable source.
    Here is a reference: http://flyingmidshipmen.com/k7russianbmbr.html
    John
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Good thing electric starters had come along by then.
  5. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    It's a beauty.
  6. ELECTRONERD
    May 26, 2009
    1,146
    16
    Holy smokes! :eek: That's gotta be the biggest plane I've ever seen!
  7. Nanophotonics
    Apr 2, 2009
    365
    Should be noisy :cool:. Very impressive.
  8. gerty
    Aug 30, 2007
    1,154
    304
    Looks like it has the aerodynamics of a billboard :eek:
  9. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The gun trurrets look similar to the ones on late WWII U.S. heavy cruisers (8" guns). That would make the turrets weigh in at around 600 tons, plus the ammo and handling equipment.
    Lotta load for 20 maybe 600 HP engines (unless only one engine drives both the tractor and pusher prop in each nacelle). It might need a 5 mile runway ending at a 1000 foot cliff. Think how long it would take to start and warm up and then do mag drops.
  10. jpanhalt
    Jan 18, 2008
    5,699
    909
    Maybe they pointed the guns aft during takeoff? Sure would hate to be following them on the active.
    John
  11. Wendy
    Mar 24, 2008
    20,772
    2,540
    I remember hearing pilots (on TV) talking about the wart hog feeling like it stopped in midair when its main gun went off. I wondered what kind of velocity change it went through.
    I could see the report on the German aircraft, both target and aircraft were destroyed.
  12. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I can say that a 5" gun will cause some jolts and motion in a space (room) about 200' forward of the mount when it goes off. That was on a 8000 ton cruiser.
  13. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Many years ago, I witnessed an A7 Corsair II fire its 20mm M61A1 Vulcan six-barrel cannon on a mock strafing run. The M61A1 had a rate of fire of around 6,000 rounds per minute. The pilot fired off about a 2-second burst, and it looked like he'd jammed on the brakes in midair!
    Biggest artillery I've heard of being installed on aircraft is the 105 Howitzer on AC-130's.
