Hello Everyone,
I am thinking of making a micro-controller based sprinkler control. I have never done anything like this, so please be gentle I do have some theoretical background in electronics, control systems and avionics from uni, but not much past the basics.
At this point I am only contemplating whether take this project on or not. Want I to create is a system that can be programmed to control solenoid valves for a sprinkler system.
Here is a rough block diagram of what I want to make.
I am planning to do this in stages. Stage one would be the making of the controller, attaching an LCD and some buttons to it and hooking it up to a single solenoid valve. For the first stage I am planing to program in only some basic scheduling options. I want to use C for programming. The system will be powered from the mains (220V 50Hz) so I'm guessing a DC power supply will be needed.
At some point in the future I would like to add some environmental sensors (such as temperature, rain, moisture, water flow rate) and more solenoid valves for different irrigation circuits (Maybe up to 8). So for this some extra input/output ports might be needed.
At this point I would like your help with designing this system. First of all, I have no idea on what components I need apart from the obvious ones in the block diagram and which components would best suit my needs. I don't want to be making a PCB so will probably using a breadboard. And I don't have a lot of money so it would be nice if I could keep the price as low as possible. Will probably be getting the components on-line, so recommendations on good stores that ship to UK are welcome.
Thank you for your help and patience.
