Spotting Short-Circuits
Discussion in 'Homework Help' started by Hitman6267, May 27, 2010.
  1. Hitman6267
    Apr 6, 2010
    82
    I had this circuit once in the exam. I wasn't sure if the 30 ohm resistor was short-circuited. It turned out it was. Is there any definition/trick that would help me be sure if something is short-circuited ?
  2. Markd77
    Sep 7, 2009
    2,803
    594
    If you can see a direct connection between both its ends then it is short circuited. You should find it when you are looking for resistors in parallel. That one is in parallel with a bit of wire so you can just ignore it.
