Spotlight Switch
Discussion in 'The Projects Forum' started by gf0012-aust, Dec 4, 2012.
Thread Status:
Not open for further replies.
  1. gf0012-aust
    Dec 4, 2012
    rather than create a new thread I thought I'd resurrect this as its a similar problem
    I have a 5 pole Bosch 30 amp relay and an illuminated carling contura II single throw switch with 3 poles, switched poles 2 and 3 and pole 7 which nominally is the earth
    the spotlights are wired into the high beam switch (legal req in australia)
    poles 2 and 3 on the carling appear to be an earth connection as the switch will only illuminate (and stays on whether switch on/off) if a positive feed is applied to pole 7
    pole 30 on the bosch goes to + battery
    poles 85 and 86 are switched through to pole 3 on the carling. 86 (can't confirm) would appear to connected to High Beam main headlights as req'd under road rules)
    pole 3 on the carling goes to the vehicle body
    poles 87 x 2 are connected to the spotlights
    does pole 7 on the carling need to be connected to High Beam to be activated or does it get added onto poles 87 on the relay?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Welcome to AAC!
    A thread belongs to the OP (original poster). Trying to take over someone elses thread is called hijacking, which is not allowed at All About Circuits. I have therefore given you a thread of your very own.
    This was split from 12v Illuminated Switch with switched neg circuit
  3. gf0012-aust
    Dec 4, 2012
    sorry about that, wasn't my intention to hijack and pollute the original post. explanation sent by email
  4. #12
    Nov 30, 2010
    16,670
    7,314
    Several things make this difficult. First, automotive modifications are forbidden on this site. Second, schematics were invented to make clear what you are trying to say with words, try to make a drawing. Third, I don't have an automotive relay schematic in my head, and you seem to have at least 2 different relays. Providing a drawing of those too, would help a lot. Fourth, you don't have a 5 pole relay, you have a relay with 5 connectors.
    I could spend most of an hour trying to figure out the schematic and still get it wrong, or I can ask you to provide one in a .PNG format.
    Now I will go poke Bill and ask if he saw the automotive aspect of your question. (He gets crabby with me if I break the rules.)
  5. gf0012-aust
    Dec 4, 2012
    I've just noticed the issue on automotive questions
    I assume Bill has seen it as he moved it from another area.
    Rather than irritate everyone it's probably easier for me to delete my registration and go elsewhere
    all inadvertent and unintentional but didn't see the fury over auto questions until after I'd gone through the rego process and by that stage had already lodged the post.
  6. gf0012-aust
    Dec 4, 2012
    Mod,
    please delete the thread
    I'm obviously in the wrong forum
    gf
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    It does not work that way here.
    From your reaction I will assume this is automotive.
Thread Status:
