hey, is it posible to split one input, 12vdc @ 2 amps, to 4 outputs and not have any power loss when all outputs have a load? if not, how do i fix it?
No, 130mA, or 0.13A.so, 1.3 mA??
0.13A x 4 = 0.52Athats good. so that means i can connect 4 to one input and all will be running at 12 volts with out any drop from input to output?
Try measuring it's output under no load using a voltmeter. I'll bet that the regulator is inside the drive rather than in the adapter.no, its a regulated adapter used to power one of those external hard drives. the plug says "+12 ~ 2A" to im guessing that its constant no mater what to load.
by Duane Benson
by Jake Hertz
by Jeff Child
