split 1 pipe into 3 , how does this affect pressure
Discussion in 'Physics' started by t00t, Jul 13, 2015.
  1. t00t
    Jan 22, 2015
    55
    So if I have a pipe and I split it into 3 pipes what will the pressure on the ends of this 3 pipes be ?
    Is p0 = p1+p2+p3 ?
    P1,p2,p3 = pressure at the ends of the 3 pipe
    P0 = pressure before splitting into 3 pipes.
    From what I have been reading p0=p1=p2=p3 . If so how can I reduce the pressure and increase flow rate at the ends of the 3 pipes?
  2. BR-549
    Sep 22, 2013
    2,178
    419
    The same. With that information.
    No.
    Decrease the diameters of P1, P2 and P3.
    Decreasing the diameter, increases the velocity.
    Increasing the velocity, decreases the pressure.
    Fluid flow flow is a science itself. It has to be analyzed as a system, with the appropriate parameters.
    You might find better luck on a steam or pumping forum.
  3. Alec_t
    Sep 17, 2013
    5,971
    1,135
    If you mean the ends remote from the splitting point, the pressure will be less than P0 if there is flow. Pressure drop is proportional to flow rate (and vice versa) if the fluid in the pipe is incompressible.
