Spinning dancer
Discussion in 'Off-Topic' started by inwo, Apr 21, 2014.
  1. inwo
    Nov 7, 2013
    2,435
    315
  2. Zerotolerance
    Member
    Sep 18, 2011
    56
    10
    No doubt about it that she's spinning clockwise. Creativity or not, I find it to be common sense :p lol. and I am definitely left brained so I think this is garbage.
  3. inwo
    Nov 7, 2013
    2,435
    315
    The interpretation may be garbage, but it does appear to spin opposite after a while.
    So far all the initial looks are CW.
    My neighbor lady took 10 seconds to see a reversal.
    I can't stop looking.:D
  4. djsfantasi
    Apr 11, 2010
    2,899
    870
    I see 90% CCW. Only occasionally does the image spin CW.
  5. inwo
    Nov 7, 2013
    2,435
    315
    Ok, that's 1 for CCW!:D
    I think I found the method (for me), to change at will.;)
  6. GopherT
    Nov 23, 2012
    6,297
    4,019
    The shadow on the bottom skews the spin. Cover the shadow and she only spins clockwise for me.
  7. Georacer
    Nov 25, 2009
    5,151
    1,266
    I had given this a shot in the past. I never managed to change the rotation direction; she always spins CCW, looking from above, for me.
  8. djsfantasi
    Apr 11, 2010
    2,899
    870
    Nope. Still spins CCW.
  9. Brownout
    Jan 10, 2012
    2,375
    998
    If I concentrate, I can change the direction I see.
  10. Markd77
    Sep 7, 2009
    2,803
    594
  11. tcmtech
    Nov 4, 2013
    2,104
    1,747
    Keeps switching back and forth for me depending on what personality I am letting drive my mental bus. :p
  12. #12
    Nov 30, 2010
    16,655
    7,293
    I can reverse it like I don't know what the problem is.
  13. atferrari
    Jan 6, 2004
    2,663
    783
    Is that thing worth all the fuss?
    Had you the real dancer in front of you, would you be confused? Almost never.
  14. Wendy
    Mar 24, 2008
    20,772
    2,540
    The optical illusion is intriguing. It is what makes it so fascinating. It is like you are feeling the circuits in your minds fighting over it.
  15. ErnieM
    Apr 24, 2011
    7,433
    1,623
    Yes it definitely is worth the fuss. So much of what we see is only what we think we see. For example, you cannot see anything you are directly looking at: that's a well known hole in your retina. But your brain fills in that little detail for you.
    Here you get to play with the workings of some of your hardware.
  16. tcmtech
    Nov 4, 2013
    2,104
    1,747
    She might be fun to look at but what's her personality like? :rolleyes:
  17. JoeJester
    Apr 26, 2005
    3,387
    1,211
    12 rotations CW...12 rotations CCW. Then repeats.
    Speaks more to the time it takes someone to decide. Apparently I made the decision quickly when it started in the CW mode.
  18. Mickster
    Member
    Jan 10, 2010
    25
    11
    Initially, the dancer always starts off CCW, but sometimes changes rotation when I look away from the screen then back again. I've tried to focus on a particular point, such as the thigh on one leg, or the toes on the other, the head, hands etc.
    There's no discernable pattern which I can attribute to a change in direction, but the shadow on the floor does seem to have an influence if I make a conscious effort to take notice of it.
  19. tcmtech
    Nov 4, 2013
    2,104
    1,747
    If I cross my eyes and slightly blur the image I can get her to be going both ways at once.
    One eye she goes CW the other she goes CCW.
  20. inwo
    Nov 7, 2013
    2,435
    315
    I found that I can change directions by watching the shadow meet the pivot foot and kicking foot shadow left or right.
    There is only one true direction, as she pivots on left or right foot.
    One direction here feet are backwards. (big toe)
