Spike Generatin
Discussion in 'The Projects Forum' started by shiva.ven, Jun 3, 2006.
  1. shiva.ven
    Jun 3, 2006
    Hi experts...
    How to generate a spike signal for duration of 50ms & the amplitude of 35 volts by giving a trigger to the circuit..
    Thanks In Advance
    Shivaram
  2. Faros
    Jul 29, 2005
    Hi shiva.ven
    What is going to trigger the trigger? … Is it a push button switch or another circuit at predefined condition?
    Why you need 35 V as amplitude of the trigging spike? Is it the Vcc in your circuit so that you required circuit should work in this voltage?
    What is the max current that this spike should supply?
    Please specify so we can be able to help you…
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    What is the slope? Is the spike supposed to be symmetrical? Or are you really looking for a 50 ms duration pulse? Voltage spikes are typically accidental. A repetitive triggered voltage waveform is usually referred to as a pulse.
