Spice
Discussion in 'Electronics Resources' started by kaosad, May 15, 2008.
  1. kaosad
    Apr 14, 2008
    19
    I am using LT-SPICE and is having trouble of finding a way to do a frequency sweeping. Can anyone help?
  2. roddefig
    Apr 29, 2008
    149
  3. Norfindel
    Mar 6, 2008
    235
    9
    If i not mistaken, the option to do that is the AC analysis (in simulate - > edit simulation cmd). For example, if you select DECADE sweep, 10 points per decade, start frequency 1m, end frequency 1Meg, the program would sweep the frequency from 1 millihertz to 1 megahertz.
    Note: you need to assign the value "AC 1." (without quotes) to the voltage source you want to use for the sweep.
    I think it's even on the help file.
  4. Ron H
    Apr 14, 2005
    7,050
    657
    Save this file in your SwCADIII directory, then start LTSpice and open the file.
  5. kaosad
    Apr 14, 2008
    19
    thanks for all the inputs
