Spice Question : Op-amps
Discussion in 'Homework Help' started by Johnny Wheels, Nov 27, 2008.
  1. Johnny Wheels
    Nov 27, 2008
    Not sure if this is the right place to ask, first-timer here.
    I don't know how to work with op-amps in spice. I need to make the opamp have some slew rate and other effects. Can anyone lead me to documentation on how to do that? I am providing you with my assignment question for people to know what I mean.
    Question:
    Use two different models of op amp behavior. The first model is an ideal model of op amp behavior (at least, a close approximation) and the second model will be one that includes small and large-signal effects. Model the op
    amp with a 2 MHz unity-gain bandwidth, slew-rate of 1 V/μs and an output saturation level of ±10 V.
  2. Ron H
    Apr 14, 2005
    7,050
    657
    What type of spice are you using? I could help you with LTspice, but it's the only one I'm familiar with.
  3. KL7AJ
    Nov 4, 2008
    2,043
    292
    You probably want to run two separate analyses on this....one being a step (transient) function, and another with a swept AC wave. Between the two, you can learn almost everything you need to know about the little feller.
    eric
