Well it is not that much easy I think. Because the same RC value with different R&C values produce a signal shape. Thus I need to sweep all the values individually and find out the best output. Thus I am interested in the possibility of sweeping different R & C values automatically.... set the RC values to three sets of values right?
So...for a single sim run, you want to step a RANGE of C values, for example, while using a fixed R value during a frequency sweep?Well it is not that much easy I think. Because the same RC value with different R&C values produce a signal shape. Thus I need to sweep all the values individually and find out the best output. Thus I am interested in the possibility of sweeping different R & C values automatically.
I ask this because you call out specific RC values, instead of ranges, in your requirements.So...for a single sim run, you want to step a RANGE of C values, for example, while using a fixed R value during a frequency sweep?
by Aaron Carman
by Jake Hertz
by Aaron Carman
by Duane Benson
