Spice modeling
Discussion in 'General Electronics Chat' started by sharanbr, Jun 20, 2015.
  1. sharanbr
    Thread Starter Active Member
    Apr 13, 2009
    76
    Hello All,
    I am looking for a document, book, tutorial that takes show how to model electrical circuits.
    The circuit can be starting from simple RLC type of components to transistor level.
    Regards,
  2. DickCappels
    Aug 21, 2008
    2,746
    665
  3. crutschow
    Mar 14, 2008
    13,469
    3,356
    I recommend LTspice also. It has a somewhat steep learning curve but the tutorial is quite helpful and there are many sample circuits that you can learn from, as well as getting help from us on this forum if you have questions.
    Once you learn Spice you will find it very useful to experiment with circuits virtually and also verify their operation before they are built with real parts. If the simulated circuit doesn't work then the chances are very high that the real one won't either.
  4. MikeML
    Oct 2, 2009
    5,450
    1,066
    I have posted hundreds of running LTSpice sims here. You can use my posts to find examples of how to set up sims...
  5. sharanbr
    Apr 13, 2009
    76
    Thanks ...
  6. eetech00
    Jun 8, 2013
    674
    115
    A good spice book is:
    "The SPICE Book" Paperback – January 6, 1994
    by Andrei Vladimirescu (Author)
    eT
