Spi mode simulator logic analyzer
Discussion in 'Embedded Systems and Microcontrollers' started by RJ_QWE, Mar 24, 2011.
  1. RJ_QWE
    Mar 24, 2011
    HELLO EVERYONE
    I AM TRYING TO WRITE A PROGRAM FOR PIC18F6520 TO FEED THE DATA IN AD9954 (DDS). I HAVE USED SPI TRANSFER MODE.
    WHEN I USE DEBUGGER AS MPLAB SIM AND SEE THE LOGIC ANALYZER OUTPUT FOR SDO PORT AND CLK PORT NOTHING COMES OUT.
    PLEASE HELP ME.
    HERE IS MY PROGRAM
    Code ( (Unknown Language)):
    1.
    2.     LIST P=18F6520        ;directive to define processor
    3.     #include <P18F6520.INC>    ;processor specific variable definitions
    4.
    5. ;******************************************************************************
    6. ;Configuration bits
    7.
    8.  CONFIG OSC = EC
    9.  CONFIG OSCS = OFF
    10.  CONFIG WDT = OFF
    11.  CONFIG LVP = OFF
    12.  CONFIG DEBUG = ON
    13.
    14. ;******************************************************************************
    15. ;Variable definitions
    16. ; These variables are only needed if low priority interrupts are used.
    17. ; More variables may be needed to store other special function registers used
    18. ; in the interrupt routines.
    19.
    20.         CBLOCK    0x060
    21.         WREG_TEMP    ;variable used for context saving
    22.         STATUS_TEMP    ;variable used for context saving
    23.         BSR_TEMP    ;variable used for context saving
    24.         ENDC
    25.
    26.         CBLOCK    0x000
    27.         EXAMPLE        ;example of a variable in access RAM
    28.         ENDC
    29.
    30. ;******************************************************************************
    31. ;EEPROM data
    32. ; Data to be programmed into the Data EEPROM is defined here
    33.
    34.         ORG    0xf00000
    35.
    36.         DE    "Test Data",0,1,2,3,4,5
    37.
    38. ;******************************************************************************
    39. ;Reset vector
    40. ; This code will start executing when a reset occurs.
    41.
    42.         ORG    0x0000
    43.
    44.         goto    Main        ;go to start of main code
    45.
    46.
    47. ;******************************************************************************
    48. ;Start of main program
    49.
    50. Main:
    51.
    52. X EQU 0X07
    53.
    54.  clrf PIR1
    55.
    56.  MOVLW 0X08
    57.  MOVWF PIE1
    58.
    59.  MOVLW 0X10
    60.  MOVWF TRISC
    61.
    62.  MOVLW 0X00
    63.  MOVWF SSPSTAT
    64.
    65.  MOVLW 0X20
    66.  MOVWF SSPCON1
    67.  ;----------------------------------------------------------------
    68.
    69.  movlw 0x00
    70.  movwf SSPBUF
    71.  call CHECK
    72.
    73.  movlw 0x00
    74.  movwf SSPBUF
    75.  call CHECK
    76.
    77.  movlw 0x00
    78.  movwf SSPBUF
    79.  call CHECK
    80.
    81.  movlw 0x22
    82.  movwf SSPBUF
    83.  call CHECK
    84.
    85.  movlw 0x00
    86.  movwf SSPBUF
    87.  call CHECK
    88.
    89. ;--------------------------------------------
    90.
    91.  movlw 0x01
    92.  movwf SSPBUF
    93.  CALL CHECK
    94.
    95.  movlw 0x00
    96.  movwf SSPBUF
    97.  call CHECK
    98.
    99.  movlw 0x00
    100.  movwf SSPBUF
    101.  call CHECK
    102.
    103.  movlw 0x00
    104.  movwf SSPBUF
    105.  call CHECK
    106.
    107. ;----------------------------------------------------------------
    108.
    109.
    110.  movlw 0x04
    111.  movwf SSPBUF
    112.  call CHECK
    113.
    114.  movlw 0x33
    115.  movwf SSPBUF
    116.  call CHECK
    117.
    118.  movlw 0x33
    119.  movwf SSPBUF
    120.  call CHECK
    121.
    122.  movlw 0x33
    123.  movwf SSPBUF
    124.  call CHECK
    125.
    126.  movlw 0x33
    127.  movwf SSPBUF
    128.  call CHECK
    129. ;----------------------------------------------------------------
    130.  CALL DELAY1
    131.  BSF PORTC,7
    132.  CALL DELAY1
    133.  BCF PORTC,7
    134.  CALL DELAY1
    135.
    136. FIN
    137.  GOTO FIN
    138.
    139.   ;*******************SPI output subroutine***********************
    140. CHECK
    141.  BTFSS PIR1,3
    142.  BRA CHECK
    143.  BCF PIR1,3
    144.  RETURN
    145.
    146.   ;*******************DELAY subroutine***********************
    147. DELAY1
    148.  MOVLW D'05'
    149.  MOVWF X
    150. DELAY2
    151.  DECFSZ X,F
    152.  BRA DELAY2
    153.  RETURN
    154. ;---------------------------------------------s
    155.
    156.
    157. ;******************************************************************************
    158. ;End of program
    159.
    160.         END
    161.
    162.
