spi interfacing
Discussion in 'Embedded Systems and Microcontrollers' started by sindhukrish, Mar 24, 2009.
  1. sindhukrish
    Feb 24, 2009
    5
    hi,
    i want to interface ads7888 to pic18f4550. pic supports 3 wire spi(all modes supported) .ADC has pins named sdo, sclk,cs.
    it has no sdi pin.
    datasheet says it supports serial interface.
    there is no mention of spi in adc datasheet.
    what are the steps to interface it with the μcontroller?
    (ADC gives 1.5msps o/p if sclk is given as 25mhz)
    pls help,
    sindhukrish.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    THe ADC does support serial comms. Those pins are:
    SDO - serial data out
    SCLK - serial clock
    CS - chip select
    If you read the data sheet for the ADC, it explains how to interface it. You do not need the SPI I/F.
