There is something awesome about a 5 pound brick of a heat sink.making the whole back of the psu a huge heatsink from an old car audio heatsink and fan.. pretty awesome psu though..
you would be correct sir... looks awesome and I mounted every 317 and pass transistor to it.. then I have an old cpu processor blowing across it..There is something awesome about a 5 pound brick of a heat sink.
Top quality wiring practices are mandatory for that arrangement, considering that this motor can pull 100 amps from a dead start.How about two switches/relays? The first to use the batteries in parallel for high amps when starting from a stop. The second would have the batteries in series for a higher voltage/speed.
Can you spell 'De-magnetization'100 amps is a lot of juice..lol..
This sounds like a good idea and not overly complicated - its a shame such a big torroid would be required for a joule theif as it seemed like something that could really improve the car. Well, things that seem too good to be true usually are.How about two switches/relays? The first to use the batteries in parallel for high amps when starting from a stop. The second would have the batteries in series for a higher voltage/speed when the racer is moving. It would almost be like a two speed transmission that way, low and high.
by Jake Hertz
by Duane Benson
by Jeff Child
by Duane Benson
