speed sensor troubleshooting
Discussion in 'The Projects Forum' started by payal.kellyyy, Jul 7, 2011.
  1. payal.kellyyy
    Mar 28, 2011
    28
    I am having some problem in a speed sensor..It is showing a low current on the plc(5.3mA).
    Please find attached the circuit diagram for the same.
    I have checked voltage across all the components of this sensor .Please find below the readings for the same:
    VR1=2.825V
    VR2=0.153V
    VZd2=8.54V
    VD1=0.66V
    VC1=8.52V
    VC3=1.982V
    OUTPUT CURRENT =10mA
    I have checked resistors also but could not figure out the problem can you help me in its troubleshooting? What all can be the possible reasons for low current in a speed sensor.
    Can you figure out in this that which component has failed in this circuit ?
    Waiting for good replies .
  2. praondevou
    Jul 9, 2011
    2,936
    489
    Where do you have this current? Are you talking about the power consumption of the sensor? According to the datasheet it's typically 5.3 to 5.9 mA.
    Or is it the output current? This depends on what you connect to the output as it is open collector.
  3. BillB3857
    Feb 28, 2009
    2,402
    348
  4. payal.kellyyy
    Mar 28, 2011
    28
    but the capacitor does not seems to be bad since I had verified there values.
  5. shortbus
    Sep 30, 2009
    4,098
    1,697
    @payal.kellyyy- One thing you don't say about your sensor or show in the schematic, is what magnet are you using?
    If you are detecting a moving magnet, no problem.
    If you are just trying to detect a gear tooth or other iron object that is your problem. According to the data sheet that BillB3857 linked to you need to put a magnet behind the sensor in that type of use. Without the magnet your sensor won't generate enough of a output.
  6. KMoffett
    Dec 19, 2007
    2,586
    234
  7. payal.kellyyy
    Mar 28, 2011
    28
    Dear Shortbus,
    In my sensor also we are using a magnet which is placed behind the Hall Ic.
