speed of propagation
darsie
Joined Feb 19, 2010
15
http://www.allaboutcircuits.com/vol_1/chpt_1/2.html
"With electricity, the overall effect from one end of a conductor to the other happens at the speed of light: a swift 186,000 miles per second!!!"
While it does happen at the speed of light, IMHO, it is the speed of light in the conductor, IMHO, which is (considerably) less than the speed of light in vacuum, 186,000 miles per second.
JoeJester
Joined Apr 26, 2005
4,390
Actually that approximate figure is for the vacuum of space. In the atmosphere it's affected by the index of refraction, and slowed further by the propagation path ... whether in the air or in a conductor. But, that's only if you wanted to get specific.
Wendy
Joined Mar 24, 2008
23,429
There are quite a few areas where we will not be getting specific. The book is a general reference. For example, Antenna theory covers what you are talking about in depth.
studiot
Joined Nov 9, 2007
4,998
Why should it be the speed of light in the conductior?
The signal travels along the conductor surface (are you familiar the skin effect?).
So joejester is right in saying the speed is approximately that of light in vacuuo.
