Speed control of a DC motor.
Discussion in 'Homework Help' started by Halim.Akiki, Feb 9, 2015.
  1. Halim.Akiki
    Dec 29, 2014
    44
    Hi. Is there any method other than the PWM (Pulse Width Modulation) to control the speed of a DC motor?
  2. MaxHeadRoom
    Jul 18, 2013
    10,850
    2,521
    SCR bridge direct off of the AC, either 2 quadrant or 4 quadrant.
    Max.
  3. Halim.Akiki
    Dec 29, 2014
    44
    I'm a BS student so and i would appreciate it if you explain more. Thank you.
  4. Alec_t
    Sep 17, 2013
    5,972
    1,135
    Controlling the current drawn by the motor will control its speed (but also vary the torque available).
  5. MaxHeadRoom
    Jul 18, 2013
    10,850
    2,521
    Three methods using SCR (or Triac) .
    The phase angle control is not shown, but just requires a fairly simple R/C circuit.
    The triac circuit would place a Triac on the AC side and then into a simple bridge rectifier befor the motor.
    Max.
  6. ScottWang
    Aug 23, 2012
    4,930
    777
    It's quite strange because he said that he want to using the pwm to control the DC motor, but you told him something that the parts using with the AC motor?
  7. MaxHeadRoom
    Jul 18, 2013
    10,850
    2,521
    I did without looking close! But it can be done with (a) & also (c) can be used by moving the motor to the SCR1 position and using a triac on the AC side.
    I will post some better (DC) examples.
    Max.
  8. Halim.Akiki
    Dec 29, 2014
    44
    Loo
    Looking forward to it. Thank you very much.
  9. ScottWang
    Aug 23, 2012
    4,930
    777
    I think you should google the key words from you as pwm dc motor, and to pick up some circuit or theory, and make your own, and then if you have any questions just post here again.
  10. Halim.Akiki
    Dec 29, 2014
    44
    I am familiar with the pwm method and i've already done it, this is why i am searching for another method. This is the pwm circuit. DC moter speed control.png
  11. ScottWang
    Aug 23, 2012
    4,930
    777
    The pwm is adjust the duty cycle to reducing the voltage and also reducing the current, if the resistance of load is fixed then I=V/R.
    As above theory, so you can reducing the power as to using LM317 to adjust the voltage, and you can also reducing the current to slow down the speed, as to using the bjt to reducing the base and then the c current will be going down.
  12. MaxHeadRoom
    Jul 18, 2013
    10,850
    2,521
    This is a very simple/basic one:
    The one down side to SCR 60hz control is switching noise at lower rpm.
    For many years before the now popular PWM, industrial servo drives were 3 phase full wave SCR control which were very smooth in operation due to the <30% ripple of the rectified DC.
    Max.
    Halim.Akiki likes this.
  13. shortbus
    Sep 30, 2009
    4,095
    1,684
    If you study BS, you have come to the right place. )
  14. MrAl
    Distinguished Member
    Jun 17, 2014
    2,556
    515
    Most of the methods today use PWM because the power requirement is reduced. With analog, the power wasted as heat could be much larger. For smaller motors however, the analog method works good and doesnt make any noise.
    The idea with the analog method is to measure the back emf of the motor and use that to control the speed. This works because there is a unique relationship between the back emf and the motor speed. With a small analog control circuit you can regulate the speed of the motor, so it's not just a control it's actually a speed regulator too.
    Years ago they used a small transistor circuit to measure the back emf and drive the small motors like that found on small cassette tape recorders. Maybe two transistors. Today we can use an op amp and get very good regulation.
    To find out how to do it this way you can probably look it up on the web, or we could discuss it further here.
    If i remember right, the back emf is simply the motor voltage minus the motor current times a constant. This emf varies in proportion to the speed of the shaft so can be used to regulate the speed (as well as control the speed).
  15. ScottWang
    Aug 23, 2012
    4,930
    777
    I haven't try this circuit, but how is the performance compare to the pure DC power supply for a dc motor?
  16. Halim.Akiki
    Dec 29, 2014
    44
    I drew the circuit on Proteus and after i simulated it the motor instantly went to full speed and would not change with the varying of the potentiometer. Here is the circuit, what did i miss? Max.png
  17. Halim.Akiki
    Dec 29, 2014
    44
    I know. And thanks to all the people here.
    shortbus likes this.
  18. Halim.Akiki
    Dec 29, 2014
    44
    I red about this relationship in electric machinery fundamentals - 5th ed (chapman) but i am not able to find a method to manipulate this value experimentally and thus control the speed of the motor.
  19. MaxHeadRoom
    Jul 18, 2013
    10,850
    2,521
    As post #12, they do exhibit some switching noise on the lower rpm's, OK for simple average tasks.
    There is a little more detail as to signal etc, in the Fairchild app note AN-3006.
    Max.
  20. ScottWang
    Aug 23, 2012
    4,930
    777
    Thanks, I will check the app note AN-3006.
    I saw the similar circuit before and they used MOC3020, but there is no similar circuit as you attached in #12.
