Speed control of 3 phase induction motor
Discussion in 'The Projects Forum' started by han, Oct 25, 2007.
  1. han
    Oct 25, 2007
    5
    hi guys,im new to tis forum
    currently im doin a project bout design a cicuit to control the speed of a 3 phase induction motor, i already hav the inverter circuit, but im having a problem to get the firing circuit.do anyone have a sample for this?really thank you if can give me a hand here...
  2. Sebi
    Sep 24, 2005
    59
  3. han
    Oct 25, 2007
    5
    thankz,but im doing a manually speed control circuit..is there any simple circuit that doesn't require any pic or plc?thankz lot for da help
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I don't think a three phase waveform can be controlled manually. You have to alter frequency to control speed.
  5. han
    Oct 25, 2007
    5
    then how do i alter the frequency?
  6. recca02
    Apr 2, 2007
    1,211
    by increasing the firing rate of the inverter components.
    usually mosfet's or IGBT's
  7. han
    Oct 25, 2007
    5
    in the inverter circuit i have 6 IGBT s, but how do i control the firing rate?
  8. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    As above: use a microprocessor. Look up "induction motor speed control" on Google.
  9. han
    Oct 25, 2007
    5
    oh.means to control the speed of an induction motor we still need a microprocessor la?theres no other way?
  10. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Of course there are other ways. But they are far more complicated and less reliable than using a microprocessor. You could, for example, gang together a control to simultaneously vary both motor supply voltage and the frequency from a VCO. It would be quite challenging to design and adjust, though. You would have to do a lot more soldering, too. In the long run, it would probably be more expensive as well. And less reliable. But you could do it.
