Speed Control and Direction control for 24 volt 250watt ( 8-10 amp) DC motor
Discussion in 'The Projects Forum' started by Erac, Aug 7, 2010.
  1. Erac
    Aug 7, 2010
    8
    I have a 24 volt 25 watts 8 amp DC motor. How can I possibly control its speed and direction?
    Please help...
  2. K-Young
    Member
    Aug 22, 2009
    27
    Your best bet is to use a PWM method to control a DC motor. There are a lot of options out there. You can design the circuit yourself using a microcontroller or buy a kit.
    Erac likes this.
  3. Erac
    Aug 7, 2010
    8
    Thanks for the reply k-young!
    I bought this motor driver ( K243) http://secure.oatleyelectronics.com/files/K243notes.pdf ,but I want to replace the potentiometer that controls the direction of the motor (When the potentiometer is centered the motor does not turn....Rotating it clockwise makes the motor turn one way...anticlockwise..the other..).
    I want the direction of my motor, to be controlled by my arduino micocontroller. Do you have any idea how?
    Hope for your support,
    Erac
  4. mik3
    Feb 4, 2008
    4,846
    63
    You can buy a digital pot and control it with the Arduino.
    Erac likes this.
  5. BillB3857
    Feb 28, 2009
    2,402
    348
    Erac likes this.
  6. Erac
    Aug 7, 2010
    8
    Thanks for the help guys!
    I'm thinking of using a digital pot to be controlled by my arduino microcontroller, but it would be much better if my arduino microcontroller can directly control the direction and speed by sending pulses.
    http://secure.oatleyelectronics.com/files/K243notes.pdf ( K343 data sheet):
    If I connect the SIG ( k243 motor controller) to the digital pin of my microcontroller and GND ( k243) to the GND pin ( microcontroller) and send pulses, would that possibly work? Can I control the direction and speed of the motor?
    Help…
  7. BillB3857
    Feb 28, 2009
    2,402
    348
    Read the item on Page 2 of your data sheet that has the header "1-2mS (Radio Control) INPUT". That should shed some light on the capability of the controller.
    Erac likes this.
