spectrum representation
Discussion in 'Homework Help' started by jstrike21, Jan 27, 2010.
  1. jstrike21
    Sep 24, 2009
    104
    x(t)= 10cos(800pi*t+pi/4)+7cos(1200pi*t-pi/3)-3cos(1600pi*t)
    I have to sketch the spectrum of this signal, indicating the complex size of each frequency component. Then make seperate plots for real/imaginary or magnitude/phase of the complex amplitudes at each frequency
    I have worked out:
    x(t)= 5e^(jpi/4)e^(j800pi*t)+5e^(-jpi/4)e^(-j800pi*t)+3.5e^(-jpi/3)e^(j1200pi*t)+3.5e^(jpi/3)e^(-j1200pi*t) -1.5e^(j0)e^(j1600pi*t)-1.5e^(-j0)e^(-j1600pi*t)
    I think this may be wrong could i get some assistance on this and A little explanation on what the bold part in the question means.
  2. MasterSnow
    Member
    Jan 18, 2009
    22
    You actually don't need to worry about breaking each sinusoid down into its complex exponential form. Since this signal is made up of nice, steady state sinusoids, you can use phasor analysis. ie Real(magnitude*e^(j*(frequency*t + phase))) = magnitude*cos(frequency*t + phase). What they mean by complex size is the magnitude and the phase angle together in an expression like magnitude*e^(j*phase). As you can see, you have three perfectly narrow frequencies in the signal, so your plot will contain three straight lines of varying magnitude depending on what you're representing. The bold part appears to mean that they want a plot that shows just the magntidue represented or just the phase represented.
    Hope this helps!
  3. jstrike21
    Sep 24, 2009
    104
    so i have Re(10e^(j400t)e^(j*pi/4)+7e^(j600t)e^(-j*pi/3)-3e^(j400t)e^(j*0)) is this correct?
  4. jstrike21
    Sep 24, 2009
    104
    can anyone give confirmation?
