spectrum analyzer
Discussion in 'The Projects Forum' started by suzuki, Nov 23, 2011.
  1. suzuki
    Aug 10, 2011
    im looking to use a spectrum analyzer for creating some frequency response plots. the circuit i am looking to measure is a voltage controlled oscillator. I know that (from measurement) that voltages from 1.0V to 1.2V will generate about 50Hz to about 65Hz.
    My concern is that my input control voltage range is too small (0.2V), and im not sure how large of a perturbation signal i should be inputting from my network analyzer. does anyone have any suggestions or comments if this will work? any tricks on how i can increase this range without have to do any major design changes?
  2. thatoneguy
    Feb 19, 2009
    A spectrum analyzer shows frequencies over a wide range.
    When looking for response of filters or oscillators, it is best to use an oscilloscope to read the frequency and voltage to calculate the range of frequencies, as well as the 3dB down point.
