Special Resistor ???? (Audio Cable)
Discussion in 'General Electronics Chat' started by electronewb, Jan 9, 2014.
  1. electronewb
    Apr 24, 2012
    260
    Does anybody know what a "special" resistor is?
    http://www.audioimplements.com/CellPhonePage.html Model Part #329 Model #HDS-93 towards the top of the page. Also mix channels together wouldn't be just jumping the tip to the sleeve? Snake oil??
  2. tracecom
    Apr 16, 2010
    3,878
    1,396
    Not exactly snake oil. It's good to put some resistance in series with each side of a stereo signal before you mix them together. I use 1k, but there's nothing "special" about them.
  3. huang
    Jan 8, 2014
    10
    what does it used for ?
    for cell phone earphone wire?
  4. electronewb
    Apr 24, 2012
    260
    Basically yes cell phone to earphone that goes to a receiver http://www.audioimplements.com/Receivers.html IFB through cell phone for on camera people. The funny thing is their "regular" cable does the exact same thing it's only tip and ring but works on iphones and Blackberrys That's why I put snake oil!!!!
    huang likes this.
  5. electronewb
    Apr 24, 2012
    260
    What would be the purpose of the resistor? And how do you wire it on a Tip, Ring, Sleeve connector to Tip, Sleeve??
  6. 4pyros
    Jan 3, 2014
    22
    electronewb likes this.
  7. tracecom
    Apr 16, 2010
    3,878
    1,396
  8. alfacliff
    Dec 13, 2013
    2,449
    428
    without the resistors, one chanel can get into the negatvie feedback for the other chanel. the resistors isolate the channels.
