Special effects with 7 segment display
Discussion in 'The Projects Forum' started by vinicaog, Apr 23, 2010.
  1. vinicaog
    Apr 23, 2010
    Hello everyone,i need some help to design this project in VHDL,could someone please help me? iam kind lost!
    Here its,i need to show the word "PUC" in tree 7 segment displays,but i need to show in this order:
    1°-display is off for 0,5 seconds
    2°-letter P stay on for 0,5 seconds
    3°-letters PU stay on for 0,5 seconds
    4°-letters PUC on for 0,5 seconds
    5°-displays off for 0,5 seconds
    6°-word "PUC" on for 1,5 seconds
    repeat 10 times then blink "PUC" with 4hz,if i press button it starts all over again from 1°.
    if someone could please help me i whould be extremely happy,also show digital diagram circuit.
    thanks!!
  2. vinicaog
    Apr 23, 2010
    am i doing it right?
    library ieee;
    use IEEE.std_logic_1164.all;
    entity eed7seg is
    port (clk : in std_logic;
    output : out std_logic_vector (2 downto 0)
    end eed7seg;
    --Displays ficam apagados por 0,5 segundo
    --Letra “C” fica acesa por 0,5 segundo
    --Letras “CU” ficam acesas por 0,5 segundo
    --Letras “CUP” ficam acesas por 0,5 segundo
    --Displays ficam apagados por 0,5 segund.o
    --Letras “CUP” ficam acesas por 1,5 segundos
    architecture dataflow of eed7seg is
    signal saida : std_logic_vector (2 downto 0);
    signal pulsos : integer range 1 to 15;
    begin
    process (clk)
    begin
    if rising_edge (clk) then
    pulsos <= pulsos + 1 ;
    end if;
    if pulsos < 2 then
    saida <= "000";
    elsif pulsos < 4 then
    saida <= "100";
    elsif pulsos < 6 then
    saida <= "110";
    elsif pulsos < 8 then
    saida <= "111";
    elsif pulsos < 10 then
    saida <= "000";
    else
    saida <= "111";
    end if;
    end process;
    output <= saida;
    end dataflow;
