SSRs started coming on the scene about the time that I was changing careers away from industrial electronics in the 1980s; therefore, my experience with them is limited and dated. Sooooooo, I need some help determining what brand/type/model SSR to buy.
I need to switch a combined 110VAC/60CY load consisting of one 1/6hp motor, fourteen 70W halogen PAR 36 spot lights, and two 23W LED floods. The design is such that the motor and 14 halogen spots cannot be ungrouped. I am currently using a Square D 8910DPA23V14 3-pole mechanical contactor rated at 25FLA (resistive) with a 24VAC/60CY coil. (Yes, I know this contactor is overkill in this particular application.) I would like to switch to an SSR in order to reduce the actuator's footprint on the enclosure's backpanel. Reliability is an issue so I need a quality unit. The mounting location is in an outdoor cabinet. The cabinet is rainproof but is not protected against temperature and humidity swings.
Any ideas/suggestions?
Harvey
Harvey
