speaker install
Discussion in 'General Electronics Chat' started by scobar, Feb 25, 2011.
  1. scobar
    Jul 6, 2010
    10
    installing a new Alpine stereo in my boat. It has the hook up for four (4) speakers but right now I only want to use two (2) any problems?
  2. PackratKing
    Jul 13, 2008
    850
    216
    Just make sure your speakers match the Ohmic requirements of the amplifier output.
    Can anybody speak to the issue of whether he should put a dummy load on the other two, or will they be OK as is ? I'm assuming no hookup = no draw from the amp.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, Alpine has been making car stereos for many years, and I don't know how many models.
    Why not look at the installation manual that came with the stereo?
    If you don't have one, look it up online. Since you didn't provide a model number, you're on your own.
  4. aegistalons
    Member
    Feb 12, 2011
    32
    I do believe you are right that you do not need to bother with a dummy load if he is not hooking up the other two speakers.
  5. scobar
    Jul 6, 2010
    10
    Thanks guys,
    I called Alpine and they said no problem with only 2 speakers, and not 4. The installation/user guide does not metion 2 vs 4, it must assume you will be using all 4 speakers
  6. mcgyvr
    Oct 15, 2009
    4,791
    976
    Not using all the channels on any audio gear is never a problem.. Like Packrat said just make sure you try to match the ohmic rating and you are good to go.
