Speaker Frequency
Discussion in 'The Projects Forum' started by ParadiseMusic, Nov 25, 2009.
  1. ParadiseMusic
    Nov 25, 2009
    5
    I'm working on an amplifier project for my electronics class and im trying to find what the best frequency for certain speakers is? I've been experimenting with an equalizer and the sub for the project and i think the crossover circuit should cut off frequency at the sub around 250hz? is this right?
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, it really depends on the individual speaker.
    Did you check the manufacturer's specifications for the speaker?
    Seems to me a sub-woofer would be for just very low frequencies; you'd use a normal woofer for say, 100Hz-800Hz or so.
    But check out this Wikipedia entry:
    http://en.wikipedia.org/wiki/Subwoofer
    [eta]
    Usually, speaker crossover networks use LC filters. The inductors can be pretty large (they look like transformers); so can the capacitors. Butterworth filters are usually preferred for audio, as they have a very flat passband, and taper off gracefully.
    However, with a subwoofer, you might opt for a more steep cutoff frequency that could be provided with a Chebyshev filter.
  3. ParadiseMusic
    Nov 25, 2009
    5
    ill look into that but these speakers were using seem to not have model numbers on them so i have no idea what they are rated for frequency wise. they do have the rms wattage rating on them though. if i applied the max rms wattage to them and started at 20khz and made my way down until the speaker stop distorting wouldn't i find it?
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    No, don't do that!
    I would start at around 120-150Hz, and slowly go up in frequency until it began distorting.
    Then go back down in frequency until it started distorting again.
  5. THE_RB
    Feb 11, 2008
    5,435
    1,305
    It probably depends more on the cabinet than on the speaker driver. The cabinet will form a resonant and/or damped system and the speaker itself is just a small part of that system. Good speaker cabinet and crossover design is very difficult, even an expert can still get it wrong, after doing the calcs and running the software it can be common to still build the thing a couple times over to get the speaker cabinet dimensions JUST right.
    Good crossover design (or speaker design) is a real art.
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The speaker itself is very significant. A 2" speaker with a 1 oz voice coil assembly will not reproduce bass, at least in comparison with a 12" speaker having a 4" 8 lb voice coil.
  7. ParadiseMusic
    Nov 25, 2009
    5
    yes i see how that would be much safer. In my class we have a lot of donated broken equipment and the speaker were using for the sub woofer is 12" with the voice coil being 8". the whole speaker weighs probably 8-10lb's. It was pulled from a bass guitar amplifier.
    One of the big problems of doing the frequency check is that the speaker is rated for 250w rms and is going to be loud doing this so i may have to find another way.
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  9. Audioguru
    Dec 20, 2007
    9,411
    896
    A speaker for a bass guitar makes a lousy sub-woofer. It is made for high efficiency at 100Hz to 150Hz which are far higher frequencies than a sub-woofer produces.
    The enclosure for a raw speaker must have a design for the spec's of the raw speaker that is used. The spec's are the volume, the damping material and whether the enclosure is ported.
