I am looking to debounce a momentary pushbutton. I have decided on an SPDT momentary switch with NAND gates. However I am having trouble in selecting the SPDT switch.
It seems as though it should be simple: 3 poles with common, open and closed. However when I look at the switch datasheets they are not like that.
The CK switch NP8 series looks about right. But it has 4 poles, and comes in 3 and 4 wire versions. I don't follow what the 4th pole is for, or the 4 wire version.
If I look at the ATEM IP series, then most are shown with only 2 pins. The ones described as NO look like normal SPST switches, and the ones described as NO/NC look like DPST!
So can anyone suggest which of these would be right for my debouncing circuit?
Thanks,
Thanks,
