Spartan 2 & 3, serial config and CS pin
Discussion in 'Embedded Systems and Microcontrollers' started by aleksazr, May 17, 2010.
  1. aleksazr
    May 16, 2010
    14
    Spartan 2 docs clearly says that, even though
    you are configuring the FPGA in serial mode,
    you should keep CS pin high.
    What about Spartan 3?
    I don't see something like:
    "Yes, Spartan 2 had an error, but it has been fixed in Spartan 3"
  2. aleksazr
    May 16, 2010
    14
    OK, when I build my board, I will toggle CS pin (with active WR)
    during serial config and will write here.
  3. retched
    Dec 5, 2009
    5,201
    313
    Im sure others are wondering the same thing.
    I do not know if there was a change between 2 and 3. Posting your results when you find out would be good of you.
  4. aleksazr
    May 16, 2010
    14
    I will post, but it will take some weeks... sorry.
  5. aleksazr
    May 16, 2010
    14
    Here I am!
    Well, I did say "some weeks"... (ad infinitum) Am I slow or what?
    I've finally done the tests, but with Spartan 3A, not Spartan 3.
    First of all, PUDC = 0. (pull-ups during configuration are activated)
    1. CS = WR = 0;
    throughout the configuration, both CS and WR were constantly 0.
    2. CS = 0; WR = toggling;
    CS was 0, WR was toggling. (the same as DIN input, actually)
    3. CS = WR = toggling;
    both CS and WR were the same as DIN.
    4. CS = WR = floating;
    both pins on FPGA were disconnected.
    Result:
    Spartan3A was successfully configured in all tests. :)
