Hello everyone!
This is an intriguing problem. But let me explain some stuff first:
When a mass is accelerated, it’s mass increases. So if someone tries to go from a point A to point B in space at some speed comparable to the speed of light, its mass will increase and more and more kinetic energy will be needed to accelerate further. So trying to go very fast may not be practical. Instead, a space jump should be used.
I think that the rest mass is due to pressure applied by ether whereas the net mass is due to pressure and drag applied by ether.
Let’s recall the simple equation of space=velocity×time. So if a moderate velocity is to be maintained, the only way to reduce distance traveled is to shrink the time, or jumping to another time dimension. Here I assume that the time flow is a variable within the Universe. For example, let’s assume that the distance between A and B is 10 light years in our dimension. But the same distance between A and B may be just 1 day in another time dimension. So keeping a moderate velocity in the new time dimension, we can go from A to B in just one day.
A possible realization may be to create a field (magnetic etc.) around the object so the object enclosed by the field is shielded from the time flow in our dimension and experiences another time flow in another dimension. Whichever direction the object travels, space shrinks in that particular direction. So the portal is basically around the object.
What do you think?
Greetings
What do you think?
Greetings
