Hello, I am new here and would like to ask for support in a problem I am having with a PLC. The Plc has 2 analog 4-20 mA outputs and I am hooking up and actuators to both outputs. The problem is the PLC doesn't seem to provide a loop powered output. And the Actuator needs this powered output to drive the actuator control wire. The actuator is powered from my 24VDC supply but the control input needs a powered loop. Can I use a pull up resistor here or am I way off Base? The PLC is a KOYO click C0-02DD2-D.I only have one wire to work with. I don't know how to power the loop.
