Sourcing and Sinking Current
Discussion in 'General Electronics Chat' started by Abhinavrajan, Aug 22, 2016.
  1. Abhinavrajan
    Aug 7, 2016
    77
    What is the meaning or sourcing and sinking current?
    What is the concept behind the terms?
  2. Robin Mitchell
    Oct 25, 2009
    738
    206
  3. Bernard
    Aug 7, 2008
    4,232
    414
    This is a real can of worms as different explanations are in use. I like the one above but think it is in the minority or is it the other way around ? Sometimes the term is avoided by using " high level output current or low level output current ".
    Abhinavrajan likes this.
  4. MaxHeadRoom
    Jul 18, 2013
    10,830
    2,500
    It generally means the output switching the +ve is Sourcing, example is a open collector PNP, if the output switches to common, then is is sinking, an example is a open collector PNP.
    An input with the same qualities has the same label.
    This is a PDF that explains it in the PLC/Industrial control context, which is common to most applications.
    Max.
  5. crutschow
    Mar 14, 2008
    13,473
    3,361
    Source means to supply current from a power source to a grounded load.
    Sink means to conduct current from a source to the common/ground point.
    From that I would think the concept behind these terms for those functions would be apparent.
  6. MaxHeadRoom
    Jul 18, 2013
    10,830
    2,500
    The links in #2 and #4 pretty much explains that if any one is in doubt.
    Max.
  7. KeepItSimpleStupid
    Mar 4, 2014
    1,259
    222
    Or the use of a sign: -10 mA or 10 mA.
    Although it's usually in the form: The output can (source/sink) 10 mA. Values can be asymmetrical.
